Hi, quite newb here and need some advice. I have a 15kg mirror (it's oak, it's big!) I want to hang in the bedroom. It already has D-rings on it so I just need to put in something to hang it from. I'm 90% certain it's too heavy for regular 'tap in a nail' picture hooks.
My house is a 1920's terrace, single fireplace with a chimney stack (about 125cm wide) that runs up through my bedroom. Everything is painted and decorated and I don't remember what it looked like underneath well enough to trust it. I've tapped back and forth across the chimney stack and it sounds hollow towards the outer edges but less hollow in the middle two quarters. And that goes all the way across the middle, not just starts, stops and starts again. I'm not certain that it's brick though. It might just sound less hollow because it's closer to or up against the brick. (Wild guess - don't know). I drilled into it with a very widdle drill bit, around the centre of the stack. It was briefly hard but then very soft (no comment!) so I went through 'something'. The drill bit was only around an inch so I didn't go very deep. Fine, greyish powder came out - Could be brick dust or plaster or out of date cocaine for all I know - I truly have no idea, but it was quite fine.
So I don't know if this is brick, plasterboard, dry wall and whether I need rawplugs and screws, "wall-anchors" or those-spring loaded things. I'm also worried if it is plasterboard, whether that's strong enough to support a 15kg mirror. I do not want to see half my wall pulling away!
Tried to give as much information as I could think of. ANY help is appreciated.
