Hanging baskets on wall vibrating/creaking in wind
7 Jun 2011
East Lothian
We've got 2 hanging baskets at the front of our house, which when it's even slightly windy creak and crank incredibly loudly / annoyingly. I'm not sure what is actually causing the noise but it is driving us mad.
Any ideas / tips on how to minimise this?
Hanging baskets are 18-20" diameter.
Slip a bit of plastic sleeving (insulation from electric flex or similar) over the hook to stop it binding.
I'll try that, but it seems to be an issue with the bracket and the harling on the wall.
That would indicate it's loose, try tightening or replacing the fixings.
Bit of plastic as advised above between the metal bits will help.
Putting some gravel in them to weight them down will make them swing less, but this ties back into them being loose so make sure they can take more weight.
Have now resolved this, the issue was in fact to do with the hook creaking against the basket's metal chain whenever the basked moved.
I genuinely thought it was to do with the bracket and wall as we could hear the noise indoors as well but the noise must have been travelling along the iron bracket and transferring through the house.
We couldn't get plastic sleeving wide enough in B&Q for some reason, so we got a black sticky-backed velcro and wrapped that around the bracket's hook, which has worked a treat.
Thanks for all the help guys.
