Have a small problem and I hope someone has the advice to get me over it.
In order to level a wall we are hanging our units on I had to put a 2" x 3" batten on the wall over a length of 200cm. The units will be hung from this batten with a similar depth batten at the base of each unit for levelling purposes. The batten is fixed to the wall using 4" x 10 screws with full length raw plugs at 30 cm spacing.
Question is can I now screw the units into this batten or should I use bolts which go through the batten and into the wall for additional security?
Thanks in advance for any advice.
