Hi all
I am in the process of converting my spare bedroom into a music room, part of which requires hanging framed slabs of cavity wall Rockwool insulation onto the walls and ceiling. The frames are 1000mm x 600mm x 180mm and made of plywood. The Rockwool inside the frames is 100mm thick. They are reasonably heavy but nothing too bad. If it would help, I can ask the neighbour to borrow their scales and get a rough weight.....
So, one of the walls is a plasterboard stud wall and I'm not sure exactly what to use. I've seen these:
http://www.screwfix.com/prods/27238/Fixings/Cavity-Fixings/Metal-50mm-Self-Drill-Pk100
and these:
http://www.screwfix.com/prods/18266...Hollow-Wall-Anchor-5-x-43mm-6-13mm-Pack-of-10
but I have no idea which would be best or most appropriate for use in both the wall and the ceiling.
Unfortunately there is not enough timber frame in the wall to screw into those, so I'll definitely have to fix to cavity sections. On the other hand - if I can, should I aim to hit joists every time in the ceiling?
Any help would be great, and if any more info is needed to help answer please fire away.
Cheers
Max
and these:
Cheers
Max
