Hi all,
Apologies if this is in the wrong section. Mods plaese move it if it is.
I want to hang my LCD TV to the wall however the wall i want to hang it on is a stud wall but is also the outer wall of the house. So the make up of the wall is the external bricks, the studs with insulation in between and then plasterboard on top.
Now, doing some initial research and common sense, i know i need to attached the bracket to the studs, but what do i do if the studs are too far apart and i cant get both sides of the bracket into a stud?
I thought about creating some horizontal batons using some 2 x 4 which will attach to the studs and then attached the wall bracket to that. but not too sure if that will work and how secure that will be. Note the batons will be on top of the plasterboard. i wont be breaking the all down!
If i do that, the screws used to attached the bracket to the batons will go through the baton but will then go into the hollow bit of the wall. Will that be secure enough.
Im hoping someone has done this before and it is possible.
Thanks in advance for your time.
