    Dismiss Notice
Hard wearing varnish or lacquer over paint?
Discussion in 'Decorating and Painting' started by Flergle, 20 Sep 2018.
  1. Flergle
    Flergle
    20 Sep 2018
    2
    Thanks Received:
    Country:
    ive used farrow & ball paint to paint my desktops (to match the wall), and I’m wondering about the best way to finish them.
    As it’s a desk it’s going to run the risk of dents and chips as things get moved around on it like a sewing machine, painting easel, laptop.
    Any thoughts as to what sort of product I should use to finish, seal and protect it?
  2. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    318
    Country:
    I painted some bookcases in F&B eggshell, to match the walls, some years ago and they are still fine.
  3. opps
    opps
    16 Jun 2006
    4,112
    Thanks Received:
    611
    London
    Country:
    Do you mean that you used F&B emulsion?
    You could use polyvine waterbased flat varnish to seal it but TBH, if you did use emulsion, it might make more sense to sand it off and then use their eggshell. Unfortunately they stopped making oil based eggshell around late 2008 so you will have to use their waterbased eggshell.
    BTW some emulsions become much darker if you apply water based varnish over the top of them.
  4. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    318
    Country:
    If the OP did use emulsion, there's absolutely no reason why they couldn't use eggshell on top of it.
  5. opps
    opps
    16 Jun 2006
    4,112
    Thanks Received:
    611
    London
    Country:
    My concern is that the emulsion won't pass the fingernail scratch test, meaning that eggshell over the top will be prone to chipping.
    Unfortunately the OP hasn't stated what finish the desktops had originally. For all we know they could have been melamine, in which case they are going to scratch regardless of whether they use water or oil based eggshell.
    I'd be inclined to recommend a large sheet of toughened glass over the top of the table.
  6. Flergle
    Flergle
    20 Sep 2018
    2
    Thanks Received:
    Country:
    Some more details:
    Ikea desk tops (abs plastic)
    Lightly sanded
    Treated with difficult surface primer (multiple coats - stuff that’s specifically for this type of surface)
    Lightly sanded
    F&B estate emulsion applied (multiple coats)
    Do I just stick any old clear varnish over it, wax it, something else? I’m not keen on the glass idea because it’s going to be a surface that’s used for a lot of different things and I find glass a) too slippery and b) a pig to keep clean. I just want a reasonably low shine finish that’s smooth.
  7. Sponsored Links
  8. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    318
    Country:
    F&B eggshell was the paint for this, rather than emulsion. I would apply eggshell over it. Or even F&B gloss, which isn't very glossy.
  9. opps
    opps
    16 Jun 2006
    4,112
    Thanks Received:
    611
    London
    Country:
    If you don't want to pay for F&B eggshell, you could use the varnish that I suggested.
    Make sure that you hoover off the surface otherwise you risk being able to see bits of fluff through the clear coats.
    I would go for three coats.
    I cannot however guarantee that the varnish won't make the paint become slightly darker. Light paints are normally OK but I have seen it happen before.
  10. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    318
    Country:
    I think you're right it would change the colour. Point being that the OP wanted the surface to match the wall :)
  11. opps
    opps
    16 Jun 2006
    4,112
    Thanks Received:
    611
    London
    Country:
    Fair call. That said water based eggshell and emulsion often look slightly different anyway.
  12. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    318
    Country:
    I have F&B Folly Green estate emulsion on the walls of my "library", and the bookshelves I built are in the same, eggshell. I agree they look slightly different, but I think that's more to do with the way the light reflects off the slightly greater sheen of the eggshell, rather than the colour as such.
  13. opps
    opps
    16 Jun 2006
    4,112
    Thanks Received:
    611
    London
    Country:
    Agreed, the colours are the same but the light refraction is different.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
