Has anyone got a pic of a 3 phase CU
it's not the only 32A mcb with a 2.5mm single cable the 2 on left hand side in middle look like they are 32A breakers
is the socket on the left really connected how I think it is?
David
:lol: Yes, david, its connected to the meter tails! Temporary electrician's supply! Didn't they teach you anything at college . . . :lol:
A bs1362 fuse has plenty of breaking capacity (15KA iirc) so as long as noone touches it it should be fine
No reason why anyone should touch it. It's not as if the rear terminals were exposed, with no enclosure, close to the iron service head, while people work around it with tools.
Oh yes... it is :roll:
Sorry for the delay in replying, I havent been to college, As Im not a qualified electrician, but NO Way would I dare do that..
I have a Baby CU mounted to a board with some rope to form a handle for the board. Mounted on this is a henley block and a double socket, the CU contains an RCD and a 20A breaker..
I'll stick to using that and not risking an explosion!
Damn right.. its bad enough messing around with live tails ;)
So next time someone says can I get 2x 4mm² or 2x 6mm² singles into a socket, we can safely say that you can actually get 16mm² or even 25mm² cables in :D ;)
I suppose the difference is when I do a rewire, its on a refurb, so we kill all services then add temporary supplies, such as an outside tap or a piece of hep after the stop tap, and a single or double socket on the wall..
I then make sure all cables are in And only connect everything when its ready to go live, as theres nothing worse than trying to add things one at a time in a CU. (If you want it neat IMHO.)
David
you can get tails down to 10mm and possiblly smaller. 10mm should fit in a good brand of socket like MK (mk don't explicitly list 10mm but they do list 2x6mm)
