i'm carrying out a similar job tomorrow & i will use some 54mm tube & 2 54*22 reducers which just happen to have had hanging about for years.
Wow! Perhaps you should cash that in with a scrap metal merchant and use a plastic tank instead.
Clearly the poster chooses to ignore some very basic advise given to him and continues to poke and hope.
To date four different heating engineers have visited and done the work I've described here.
They say it's an odd problem for which there's no obvious cause. The location of all components in the system is (according to them, and to my own inspections) straight out of the textbook.
Here is an experimental thought. Take U shaped tube open both ends. Pour water into this U tube. Water will be at the same level in both limbs. Gently blow down one limb. Now water will be at different levels in each limb due to different pressure acting on each limb.
Now transpose this thought to your heating system. Differential pressure is created by running pump. I stress the dip in the vent pipe (your own admission that it will drink more than 500cc of water) has to be absorbed elsewhere and is likely to be the header tank.
500cc of water equal a slug of water 1.5m long in 22mm pipe. Same quantity of water in a header tank 300mmx450mm only raises water level by 3.7mm. Only way you will notice this difference in water level is to use a ruler as a dipstick and take before and after readings.
Clearly you fail to see the point I am making. Nowhere have I said water can be compressed. Nowhere have I said water can flow in two directions within the same pipe.
What I have attempted to explain is that the dip in the vent, be it boiler is sitting at the center of the earth core, is pushed by non compressible water into the header tank. When pump stops, water rushes up the vent pipe to spill over into the header tank before settling back as it would in the U tube described in earlier post
Common on the inlet side of the pump. Has anyone suggested that ? - sorry I haven't reread 6 pages.I'm thinking that the air is getting into my system on account of this kind of exchange.
I can sympathise with that, I'm a moderator on another forum where the average thread is 30 pages long and people grumble like crazy if someone joins in on the end without reading everything first!Common on the inlet side of the pump. Has anyone suggested that ? - sorry I haven't reread 6 pages.I'm thinking that the air is getting into my system on account of this kind of exchange.
Even pressurised systems will do it. You put the pressure up and it stops. So check/remake the joints that side if it's a big problem. Yo could try a leak sealer.
just for the fact of writing something different, had you thought of upsizing the feed, 28mm all the way back to f&e. then you'd have more chance of pulling water back down rather than air. i'd be sceptical of the feed that you have at present anyway. just another one for the hat!!
