ChrisR said:Plenty of silicones do stick to pvc, LSX for example. Not that it's necessary in this case - washers don't stick either - and the silicone would be anchored in the middle. It would also outlast ordinary rubber washers very well.
I know two sources of different section "rubber" washers which would fit but they're all low grade stuff and wouldn't really be suitable because of low fatigue and oxidation properties - though some non-plumbers would use them anyway.
Here's a Quite Interesting fact. Recently I fitted a PolyTank (TM) instead of the usual Titan ones that my local supplier stocks. I think I just fancied a change. It came with pairs of truly nice washers - a rubber one for the inside and a nylon one to stiffen the outside. I used the precise size of hole cutter that PolyTank specified, and the tank connectors screwed in with an interference fit, and sealed like a snug bug in a rug without any hint of silicone or boss or hemp. And no leaks at all. Well done PolyTank.
Anyway, onwards to my point. When fitting the next Titan I called the manufacturer to ask for their guidance, since they don't supply much in the way of washers and I like to keep an open mind and learn whenever possible (creep). And here's the rub - they said that on no account should I use silicone sealant, because a component in the sealant causes the cistern (aka tank) material to become brittle and liable to cracking.
Anyone else heard of this?
