Went to have a look at a friends partly built conservatory tonight and found something I didn't like.
Its a full length glass style with just the house outer wall being brick. The company doing it have agreed to install 2 double sockets on this wall for her.
The 2 galvanised back boxes are in place about 9" off the floor level, too low as I believe they should be 450mm, (15"), a 2.5mm T&E cable has been brought through the wall from the kitchen about 5' high and run down to the right hand box at an angle of about 60 degrees, (outside safe zone), then another length of 2.5mm run horizontally across to the left hand box. There is no FCU installed, (2 doubles as a spur, not allowed?). She has been told when the plasterer comes on Friday he will 'Dot & Dab' plasterboard over the cables to "hide them".
I have explained how they should be run vertically in the safe zones and they should also be in steel conduit as they will not be chased in to 50mm.
Should the ring main they come off also be RCD protected? It is from the kitchen socket which is not a dedicated ring but in with the lower ring main.
She is going to mention this to the contractor tomorrow, (Thursday), but if he says it is alright and I am just being 'fussy' do I have the right to insist he does it correctly on her behalf or will she have to stand up to him herself? She is a divorcee so doesn't have a man to back her up.
Any info would be gratefully received.
