The HC60NG controlled by my CM927 seems to have given up. When a call for heat occurs the green light on the relay box turns on and immediately turns off. The same thing happens if I press the button on the relay box. I have also tried new batteries in the Prog-stat and it makes no difference.
I assume this means the relay box is dead, unless someone can suggest a alternative explanation, so a new relay (BDR91) is required.
The date code on CM927 is 2407 (week 24 2007). I bought it, new, in 2007, so it has done nine years, which means the relay has switched on and off thousands of times.
