Head Gasket failure!? My Ka Mk1 project....
Ok, interesting development....
Head Gasket test seemed to show no combustion gas.
Engine was up to temperature, I could see a regular slow air bubble as the engine ticked over pass through the tube, through the blue liquid, and it did not change.
I then realised the heater and fan were not on full for full circulation and when I turned that on, even the air bubble stopped and there was seemingly no gas escaping. The colour stayed blue. I even added a little squeezer to the tube and pulled air through the fluid and still no change.
There were two instances where the fluid went green, but I put this down to user error. I let the car heat up too much and the coolant had expanded to the top of the tank and it interacted with the tube. The second, again the engine was too hot and steam made it's way into the test tube and seemingly contaminated it.
So I am pretty sure I can exclude those two attempts.
So......I am pretty certain the head gasket is ok........I think.
But.....the initial overheating cause is still a problem it seems. Not a one off......
The car was taken on a long drive, and it did not overheat. In fact, it was difficult to get it hot enough to make the fan come on. It stayed in the early 90s and rarely went higher.
Then after finishing the drive I turned the engine off. The temperature rose at this point to around 102 and it was enough to make the fan activate.
So we can exclude fan failure.
However at this point something went amiss.
I went to check the coolant level and it had lost about 500ml, it was low on the coolant vessel.
But again, no indication of where it leaked from.
So either there was a coolant leak whilst driving, either a sudden release due to pressure or something else.
I can't see a drip or leak whilst the engine is idling.
Any ideas where to explore next? Pressure cap, thermostat micro leak and water pump?
A cold pressure test of the coolant system?
Edit: Now leaning water pump failing.
1. It has not been replaced in 18 years
2. I have always noticed it being slightly damp in plastic bumper undertray near the water pump. While there is no evidence of red fluid, it has always struck me at odd it always seemed to be damp near here. I always put it down to rain water draining to this point, but the water pump is just above it. So i am thinking there has been a slow leak for a while (hence the very slow but noticeable coolant loss), and now it has accelerated.
Does your car have a plastic under tray that you can remove completely for a while? So long as the roads are dry, there shouldn't be any dampness there.
If so, take it off and see if anything is visible there.......all plastic parts are prone to failure, and the water pump is also a suspect - but you'll need to remove the belt covers from this. Surely there will be colour traces somewhere.....!
One other thing......check the carpets inside below the heater unit for any dampness.
At this sort of age, I'd also say the radiator could be on borrowed time......look for damage where the core joins the bottom tank.
John :)
There is not a total engine under-tray, it's more of a bumper under-tray, which forms a kind of collecting area. The side I notice the water collecting on sometimes is near the water pump housing, but also the radiator.
I'll see what happens after the next downpour (as i ensured it was dry). If it gets wet, I know rain is at least one certain cause.
Today I did a more aggressive idle test. holding more revs, trying to replicate getting it very hot and shutting off it off at peak temp.
This time it got it hot enough for the fan to activate a few times. It never went above 102c.
I monitored the expansion cap, had a good view of the water pump, radiator and thermostat housing. I even put paper towels near those areas to try and clearly catch any drips. Nothing at all.
So my next guesses are:
1. It is something that only presents when the engine is under more load at higher rpm.
2. That there is no issue and the most recent coolant loss was it settling and just dropping, as it was it's first hard run since the initial breakdown.
2a) this would mean the first coolant loss had to be a one off. (which would be unlikely maybe?)
3.I had a really good look for red stains or anything to indicate coolant being dumped at high temp. But I can barely see anything. No clean spots or marks on the bonnet underside. Nothing that looks like something has sprayed the interior with red hot fluid. I can see some very vague redness in the area around the water pump. But it is very hard to tell if this is the remnants of fluid or just dirt or something.
I guess my next options are to try another test drive and replicate what happened last time, or an actual coolant system pressure test?
