Head Gasket failure!? My Ka Mk1 project....
8 Jul 2008
Derbyshire
Well, this was an unexpected event in my ford ka mk1 maintenance journey.
It looks like the head gasket has failed.
The car had been on a long journey. Although when the event happened, it was the following day after a 15 minute run, and the coolant temp light came on. Hopper was near empty. No sign of fluid in the oil, no mayo.
Fluid was added, and the car ran fine back to a safe place, no further sign of coolant loss.
At first I was hoping it was the heater control valve, but there was no sign of actual leak after running the car. There was some evidence of boiler over, but only very slight (a few tiny drops of red coolant near the hopper, but no large soaked area).
The RAC came out to investigate and did a exhaust gas check and reported there is a very slight colour change.
They then surmised that it seemed like the thermostat was not opening.
So, It looked liked the thermostat failed initially and then the engine cooked, even though the car was stopped quickly.
People may remember i did a major flush of this car's coolant system and replaced the thermostat 2 years ago. So, I’m a bit miffed the thermostat failed. I documented it here.
https://www.diynot.com/diy/threads/ford-ka-mk1-coolent-flush-query-and-questions.632020/page-2
Could that heavily lime-scaled coolant that sat in the engine for years beforehand have done more damage than i realised?
Apparently there is an issue with the thermostat housing (failing seal?) and a trapped air pocket that can cause thermostat failure like symptoms. (Need to check if this is true)
So, prognosis..... head skim and a new gasket? Like i said, no signs of mayo yet.
Thoughts on where to go next, much appreciated.
Real bad luck, that one!
Let's not jump in too soon, remove and test the thermostat once more, then fill up with coolant and start up. You'll feel a surge of heat when the thermostat opens if you hold your hand on the radiator. Then, look for bubbles and maybe some oil in the header tank. If your engine has the iron head, a skim isn't usually needed!
Regards
John
This is the 1.3 duratec, so cast iron block and aluminium head I think.
Thermostat was not opening when the RAC guy ran the car (i was not there in person).
There is a potential known thermostat housing issue with this car where an air bubble can form there caused by a potential micro crack in the thermostat housing. This could have prevented the working thermostat from firing.
The coolant temp sensor is in this location so I could remove it to see if any air escapes.
Are you saying that oil may not show in the header tank until the thermostat has opened up all the way and let coolant circulate via the radiator?
Your could buy a combustion leak tester that fits the expansion vessel...the test liquid changes colour in the presence of combustion products.
See my op ^. The RAC guy did that and said there was a very slight colour change detected. It sounded like it was a very weak colour change, but a colour change non the less. It did not go bright green or yellow. (I was not there to see this in person).
The person who was there said they could not actually see a noticeable change from blue. But that is obviously someone without any experience in assessing the expected colour change.
Would getting a follow-up of compression tests, Pressure test and a leak-down test be the next best course of action?
A compression test would (probably) only show a leak between the combustion chamber(s) through the gasket - not necessarily into the waterways.
I've used the colour test kit before - it was conclusive on a major failure but a lot less so otherwise.
I can't say if the alloy Duratec head can be skimmed - not all alloy heads can so you can investigate further before considering head removal so I'd replace the thermostat with a genuine item, bleed all coolant air out as you can, run the engine up to temperature with the heater on and see how you go.
Fingers crossed for you!
Regards
John :)
Thanks @Burnerman I'll do that next.
Just to clarify the full series of events.
History
Car has a brand new OEM (ford) thermostat installed, and fully flushed and fresh coolant (OEM spec) added.
Coolant level is noticed to be slowly dropping over time, but not at a concerning rate. It is topped up to max, but slowly drops to around or just below minimum over 6 months to a year.
Car performs normally in that time for 2 years.
Coolant was around min or just below just before the event, but the header tank still had a lot of fluid in it.
Event
1) Car performs fine on a long journey (200 miles on the motorway).
2) A few days later after a short 15 minute drive, the coolest temp light comes on.
The car is stopped immediately.
There has been a sudden loss of coolant. Maybe 1.5 litres out of 5.2 litres in total. The car has clearly over heated for some reason.
There is no evidence where the leak came from, but most likely the emergency valve.The car is allowed to cool down and the coolant is topped up with water to the correct level.
Roadside Checks
No coolant in the oil (or visible milkiness)
No misfires or white smoke.
Once cooled it is driven to a safer location and left for the night. The newly added coolant drops a bit in that time but there is no evidence of a leak.
There are no odd engine sounds or loss of power.
RAC Diagnosis
Two tests are performed the next morning.
He finds the thermostat is not opening as the radiator is not getting warm.
Combustion gas coolant check: He says that changes slightly from blue, but apparently only very slightly. While the mechanic can see a very slight change from blue, the driver cannot see much difference.
Determines it is a head gasket failure.
So....
I am wondering if air was being drawn into the system somewhere (hence the slow coolant loss over time). Then the long motorway journey and then cooling after maybe caused the pocket to finally form in the thermostat housing, which eventually led to the overheat event.
Maybe there is some hope that the gasket has not failed, and it was just an overheat, with a false positive on the gas test..
Curious indeed.....!
However, Mr. RAC determined that the thermostat wasn't opening.......if this is the case, no wonder you had coolant loss.
Didn't he comment on that?
Regards
John :)
I was not there in person but I was listening via the phone. Essentially he said, "thermostat failed, that caused the overheat, and the overheat was enough to cause a gasket failure".
He knew the coolant loss went via the relief valve, but took the very slight colour change from the coolant gas test as confirmation the gasket had failed.
I'm now wondering (maybe hoping) if there was just an overheat due to a air pocket. And the gas test was potentially a false positive.
But that gas test would have been done on a system that had a closed thermostat (which, as I understand, is not exactly reliable).
Ka mk1 2008 1.3 Duratec 40k on the clock.
Edit: Additional info - The person who watched the mechanic says the fluid looked teal blue/green to begin with, and did not change much from that colour. They did not see it start off a deep blue.
But, this is the only variable I could not witness.
Got the car back and having a look myself now.
I think i will have to buy an exhaust gas tester as garages are so booked up.
One more positive note is that the hoses for the coolant system do not get rock hard whilst the engine is running.
As far as I understand this is also a good indication that exhaust gasses are not leaking into the coolant system.
Update:
Decided to run the car fully up to temp on idle. thermostat opened fine - Car idled at 90c.
Hoses still soft to squeeze at at this temperature.
Fan did not need to come on at idle.
No white smoke
No issue with oil
So......I may be in luck.
I think a fresh exhaust gas coolant test is a good idea.
I was entertaining the idea there could be a microleak, but from what I understand, even this would probably cause the hoses to harden up with pressure.
The pressure cap on the expansion bottle is set to around 13 psi - which effectively raises the boiling point of the coolant to around 120 deg C.
If you ever get to this temperature the radiator pipes will be rock hard and the cooling fan will be on big time!
An engine does need to be worked though, rather than brought up to temperature on idle, so please observe this in the next day or so. You should also be able to remove the pressure cap, but do be careful as the temperature may shoot up as pressure is released!
The fan won't be on at 90 deg, but shouldn't be far off if the temperature reaches 100.
Hopefully, you will have got away with it!
Regards
John :)
From what i understand, if there was a combustion leak into the coolant, the pipes would get rock hard pretty quickly. Correct?
Or are you saying the engine needs to be worked harder for combustion gasses to pressurise the pipes?
Or is this to test if the fan is working.
Help much appreciated.
If there was a combustion leak into the cooling system, there would be coolant expelled from the expansion bottle - irrespective of temperature really, although a hot engine would react more quickly and the pipes would harden after a while.
To be honest, I don't think an idling engine is a good test - I'd drive the thing pretty hard for a couple of miles (once warmed up) stop, keep the engine running and check the coolant level again and again.
John :)
