I have an Albion Mainsflow heatstore which provides hot water indirectly via a coil running through the store. Water is drawn directly from the store for under floor heating. In recent months I have noticed water coming from the over flow of the expansion/feed tank located above the heat store. Initially the flow seemed to be related to the cycling of the boiler and I thought the immersion thermostat controlling the maximum temperature of the water in the tank was to blame. However, tests suggested this was not faulty.
In recent days the flow of water has become continuous, albeit only a drip when the boiler is not cycling. I have checked the ballcock controlling the flow of water into the tank and this seems to be shutting off the water OK. Reluctantly and by various tests I have concluded that water is entering the heatstore from the coil which passes through it. My questions are as follows: Are there other possible explanations? Is a repair possible or must I replace the tank? As this problem has been developing for a period during which I think I have misidiagnosed the problem, how quickly must I repair the problem before irreparable damage is done to the system? As the central heating is underfloor, pipe work is largely plastic. Other pipework in the system including feed and return to the Grant boiler is also plastic. I assume corrosion must have taken place in the copper/steel elements of the system (e.g. the small expansion vessel connected to the heat exchange coil.) Finally, my question is, why has this happened and how may it be prevented in future?
Though I am not an expert, I installed the system as part of a self build project according to a design I bought in. It has worked very well indeed continues to do so apart from the problem described.
