Im sure someone can easily answer this. I have an old heat exchanger i want to use in a project for my truck. The heat exchanger has three, what looks like compression fittments and one screw fitment. what adapters do i need to connect hoses to all four outlets?
for those that are interested - I camp alot and would like a hot shower now and again so im going to fit a heat exchanger into the radiator return hose from the engine thus circulating the hot water through the exchanger. then using a 12volt pump, pump a second cold water supply through the heat exchanger. the idea being the heat from the engin coolant heating out the cold water pumped through the heat exchanger.
[/img]
