hi,
I have noticed that my central heating doesn't seem to be disbursing heat evenly around my rads.
Here's a breakdown of the system,
- All rads are 60 cm high
- All upstairs rads are single convector
- Thermostat is at top of stairs in hall
- The living area is open plan
- All rads except the hall rad have built in thermostats
Sabre 25HE Condensing boiler (situated in Bedroom 1 / Back room)
90 cm rad (bedroom 1)
60 cm rad (bathroom / back room, directly behind boiler)
120 cm rad (bedroom 2 / boiler is directly behind boiler in bedrrom 1 / front)
60 cm rad (bedroom 3 / front)
140 cm single convector (downstairs hall / main controller rad)
60 cm double convector (living room / back area / downstairs)
120 cm double convector (living room / front window bay / downstairs)
All the rads downstairs are outputting the same amount of heat and are set to high on the individual thermostats
The bahroom rad is set to 1 and outputs the same heat as the downstairs rads that are set to 5 (max)
Bedroom 1 is outputting less than the bathroom and is set to 4
Bedroom 2 & 3 are also set to 4 but is outputting even less than bedroom 1.
I have checked the pessure on the boiler and I can't get it to go any higher.
Is there any reason for it doing this and why?
