Hi
I'm doing up the living room and I've had it plastered including inside the fireplace which has a log burner in it. The plasterer has put fibreboard inside the fireplace and not skimmed it because he said the heat would crack the plaster. Planning to paint this board with heat proof paint.
My problem is that the board doesn't quite reach the hearth tiles i.e. there is a 10mm gap or so between the tiles and fireboard.
Can anyone recommend any type of 'filler' type material that I can use to fill this gap. Needs to be something heat resistant and paintable.
Many thanks for any help
