Having removed the radiator, we have found that both pipes extrude from the same hole. We had intended to lengthen one pipe for fitting the towel heated towel rail..problem is there is a vertical plinth from top to bottom inside the cavity wall.
Any suggestions without pulling most of the wall off?
