Hi all,
I'm fitting an heated towel rail in bathroom.
In truth, it's already on the wall, it's just not wired up yet.
The heating element is rated a 400W.
I was going to take a spur from a normal ring mains double socket to power this heating element and just wanted to check what gauge cable I should use?
In truth, I'm not actually going to do the wiring myself as there's a digital time switch involved and I don't understand what goes where.
However, I'm trying to do as much of the preparation as I can before I get the sparky in so I'm going to route the cables myself.
I just wanted to make sure I use the correct cable before I make the walls good again.
I take it just the same cable that makes up the ring main is the one to use? I can't remember what it's called but they generally label them by what they're used for in homebase anyway.
Am I on the right lines? (no pun intended!).
Thanks,
DIYC.
Thanks,
DIYC.
