heated towel rail valves
30 Oct 2006
Nantwich
i am planning on replacing a radiator with a HTR. However the existing pipes that come up through the floorboards are only about 8mm dia. all of the valves i have seen are 15mm. any advice on how i go about installing it? thanks
Use an 8mm reducing set, available from all plumbers merchants. Or, lift floorboards and change the pipe to 15mm. (15mm will look better)
