Hello, again
I'm at the final stages of designing my shed which is going to be an outer games room complete with pool table, bar and arcade machines.
It will be a 29 sq/m floor area shed with 75mm of Polystyrene EPS to the Walls, Ceiling and floating floor. 18mm Ply to outside and Plasterboard to inside.
The whole room will be completely sealed, 1 double glazed door to the front and one to the back with slight ventilation.
My worry is the Polystyrene can keep things cool as well as warm. If i do not heat the room constantly, its going to be blooming cold inside!
I want it at a temperature where i can play pool with a jumper on, not too warm but comfortable.
As the Walls, Ceiling & Floating Floor are Insulated with 75mm EPS, i'm hoping the use of a blow out heater on for say 5 mins every hour will make a nice ambient temp but not sure if i'm correct?
Will the shed hold the heat?
Any advice much appreciated.
Ron
Ron
