- Joined
- 27 Jan 2008
- Messages
- 27,550
- Reaction score
- 3,330
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
When one sets something up one tries to work out what is likely to happen. I bought two controllers as STC-1000 with double relay and a MH1210A with single relay, both rather simple devices they have a differential which can be set minimum for STC-1000 is 0.3°C and can be used for heating and cooling, The MH1210A it is 0.1°C minimum and can be used for heating or cooling. There is no pulse width modulation simply on/off also with a programmable delay on start.
So I use these units to keep my brewing beer at the right temperature using an old fridge/freezer a demo under floor heating tile 18W and a CFL of 8W and to start with only used to heat, as only one controller the MH1210A.
Once the weather started to improve I found it would over shoot with the 18W tile, and once too hot 40 pints takes a lot of cooling down again, the sensor was held tight to fermentor under a sponge to insulate it from the air. The 8W bulb was a lot better, and I assumed due to size, using an energy meter it showed only really needed 5W in the heart of winter to maintain a temperature of 20°C.
Now the refrigeration motor is a fixed size of around 80W, so my thoughts were, if 18W causes over shoot on heating then 80W on cooling would result in a massive over shoot on cooling, so idea was to use one controller to heat and the other to cool to increase the gap between heating and cooling to stop any yo-yo effect.
However when it came time to cool, there was no over shooting, now on second brew to use cooling and even on first switch on with 2°C to cool set with 0.3°C differential the freezer air did cool to 5.4°C but the fermentor came down to 18.5°C set and the only time it went over the 18.8°C when the fridge should be turned back on was due to the time delay set on controller and the time the freezer takes to do a system check. So on first switch off, it rose again to 19.1°C.
It is a frost free freezer so there is of course a circulation fan when freezer is on, also the fermentation does release some heat. But even set to 0.1°C on heating it over shot by 2°C yet on cooling it is really spot on.
I can’t explain why it works so well on cooling but not on heating, using the 8W instead of the 18W heater did improve the heating so over shoot was only 0.5°C, but 18W v 60W the cooling should have been worse not better.
So any ideas why?
So any ideas why?
