first post here so please forgive me! Also, many thanks in advance for your help!
The problem is, my gas central heating seems to be staying on longer than required. Digital display will read 20c for example and the heating with stay on and hot until I switch it off at the mains. Little flame on the display that indicates heating has kicked in does not display past the tempeartaure I have set it at, but the heating just carries on! I think it has been coming on in the night also as sometimes I get up and the rads are hot, even though they shouldn't be. It seems the little green light on the Altech switch below the bolier comes on and stays on which I think indicates the heating is on and has kicked in.
I don't get any error messages with the light blinking - it is constant. The manual says the light should flash if there is a probelm?!
This has only been happening very recently. My hot water is fine, radiators all hot apart from one which only really gets hot at the bottom and not the top. The closest radiator to the bolier.
Any ideas..? Not sure what to do!
I have:
Bolier: Worcester Greenstart 24i Junior Combi Mark 4
Altech switch below boiler with red and green lights on.
Altech digital display in the dining room.
Thanks again, Damien.
I have:
