Help, my combi boiler is doing my fruit in! I've read the forum about radiators being warm when the heating is switched off and then replaced valve but ours is similar but not sure what it is.
We have a combi which does the water and heating on the same switch and clock. And a room stat in the hall and above the boiler a frost stat. A guy fitted a valve as it had stuf and evrything was ok for a short time. then this happened:
The boiler rocker switch was switched to water & heating. The timer in the airing cupboard had power to it but was not activated or timed to come on. it was in the off mode. Then the room stat was was on low. At about 2.30am in the morning (when it was supposed to be off and was not timed to come on) the heating sparked up and was heating the whole house. Even switching the room stat down, the heating remained on. the only way to switch it off is via switching the power off to the timer clock and shutting the system down or to go and switch the rocker switch just to water setting. When it is hot, the room stat has absolutelty no control over switching the boiler on and off and bringing the temperature down. i.e the pump can still be heard pumping water and only way to get it to stop is switch the whole thing off.
Any ideas as our boiler man hasn't a clue and we had to pay him for stuff done so far! He has changed the valve in the boiler as it was stuck so that should have eliminated that one. Any help here would be much appreciated!
