Heating issues
I came across this type of problem once - It turned out to be the motorised valve needed replacement (complete). It was throttling circulation
All upstairs rads were hot, downstairs were luke warm or no real heat at all. Sealed System with microbore to the Rads.
Posted: Thu Jan 30, 2014 4:22 pm
Read more: http://www.diynot.com/forums/plumbing/heating-issues.391650/page-2#ixzz2ruq6GUYt
Thanks for that, but why we're the rads getting hot after balancing.. Then go cold,,
D hailsham
Thats what I have done, a little at a time and to to get all rads to be near the same heat i have ended up with what I have , but they still go cold after
The pic shows a gate valve to the right of the pump. It appears to be on a bypass.
As you have a mid-position valve, so there will always be at least one port open, it's debatable if a bypass is necessary. Try closing the gate valve and seeing what effect it has.
