Hello,
I have a newish boiler (Worcester Ri), which when i put the heating on seems to fire up for a minute or so then stops. I am guessing that i may have a problem with the actuator (BGMVSP-23). When i put the heating on and push in the switch at the front of the actuator it goes to the 'M' position, this is when the heating kicks in and after a minute or so it goes to the 'H' position which i guess means heating and the burner on my boiler then turns itself off! I can still get hot water and this morning when i turned it on i did get a little bit of heat in the radiators, but not much! We did have a power cut for a few seconds a couple of days back and i wonder whether it has caused the problem, i have tried turning everything off and starting again but to no avail -please help!!
Regards
Regards
