I'd like some advice about which direction to go with heating our house.
We've just moved into a fairly large 5 bed semi which is not near mains gas (I've checked). It has 4 x 47KG propane tanks feeding a very old potterton boiler. I believe this is going to be expensive to run!
TRV's all seem siezed open so rooms get very hot - I've reduced the flow in these rads to try to keep a lid on it.
There is a cylinder near a v small bathroom. adjacent is another airing cupboard with a mass of pipes - also near the bathroom.
In addition there is a rayburn regent which feeds 3 separate rads in the house (with a pump) - this seems OK. Boiler is currently in the kitchen directly below the bathroom, rayburn is also in the kitchen on the other side.
As well as insulating the loft as much as possible and checking cavity insulation, I've been thinking about whether we should replace some/all elements of the heating system.
in our last house we had a natural gas baxi combi which was great, I like the idea of only heating water you need and the shower was great.
Would it be a fairly straightforward swap to replace the potterton with a modern lpg combi? At the same time reducing the mass of pipes and removing the tank?
I am assuming that this could be achieved quickly and without too much disruption to the existing infrastructure.
Is there are method of running the rayburn in tandem with a gas boiler of any kind?
TIA
Andy
TIA
Andy
