    Dismiss Notice
Heating water - electric only, advice please.
Discussion in 'Plumbing and Central Heating' started by Pickup, 7 Sep 2016.
  1. Pickup
    Pickup
    28 Oct 2009
    149
    Thanks Received:
    7
    Aberdeen
    Country:
    Hi folks,
    Looking for some advice please. First floor, 1 bed flat in a 3 storey building, 1980s housing estate no gas or oil in scheme ie all electric. Central heating is night storage off-peak, water heater is immersion heater in 110l tank again off-peak but with timer facility to "boost" water heater for up to 1 hour during non off peak periods. There is also an electric shower.
    Problems are :-
    1 - the hot water tank (used to supply 2 sinks (1 in the kitchen & 1 in the bathroom)) is located in the wardrobe (in the bedroom) so at about 3:30am there is the sound of 1000 kettles boiling 3' away from your head and then again at various intervals during the night.
    2 - hot water pressure is incredibly poor, takes over 9 minutes to fill the kitchen sink (height differential between HW tank outlet & sink is about 0.3m)
    So... is there any substitute for the existing HW system that would give mains pressure hot water and ideally be capable of providing HW to a shower as well as the kitchen & bathroom sinks?
  2. Sponsored Links
  3. Mechanical Matt
    Mechanical Matt
    10 Oct 2015
    112
    Thanks Received:
    19
    Country:
    Yes. ACV cylinder with 6kw immersion. As long as you don't have a bath 160ltr will be fine. You can run 4 wet radiators from it too so you can remove the existing terrible night storage heaters. Call a local heating engineer with experience in ACV cylinders to get a quote.
  4. Roger928
    Roger928
    10 Aug 2016
    2,631
    Thanks Received:
    201
    Country:
    Will these things go pop if you fill them wrong?
    • Thanks Thanks x 1
  5. Mechanical Matt
    Mechanical Matt
    10 Oct 2015
    112
    Thanks Received:
    19
    Country:
    Possible!
  6. Sponsored Links
  7. endecotp
    endecotp
    2 Dec 2013
    3,936
    Thanks Received:
    507
    Country:
    That's extraordinarily slow. Are the other hot taps similar? Has it always been like that?
    The height difference that matters is between the water level in the header tank and the tap. Is there a header tank immediately above the hot cylinder, or is it in the loft?
  8. Pickup
    Pickup
    28 Oct 2009
    149
    Thanks Received:
    7
    Aberdeen
    Country:
    Thanks folks,
    Always been like that (well since we've had the flat) , header tank immediately above cylinder (built in??). Other people in the block we spoken too have exactly the same complaints :)
    Thanks again
  9. Hugh Jaleak
    Hugh Jaleak
    3 Feb 2008
    7,232
    Thanks Received:
    1,689
    Northamptonshire
    Country:
    If it sounds like its boiling, I'd check the stat and make sure the temperature isn't set too high, wants to be about 65° C max.
    By the description, you have a 'Fortic' type cylinder, maybe worth looking at an 'unvented' type cylinder. These provide mains pressure hot water, with the advantage you are still able to heat it off peak. Due to the nature of these you will need an installer with a 'G3' certificate and they also require an annual service for safety purposes. If you have/use a bath in the property, this may be your best option.
    Alternatively, if you are only filling the sink and/or basin, (not a bath), there are other water heaters available that will supply at mains pressure, (although if you are heating water as you require during the day it wont allow you to take advantage of off peak electricity prices), these are somewhat smaller and can even be fitted in a kitchen cupboard under the sink.
    • Thanks Thanks x 1
  10. Pickup
    Pickup
    28 Oct 2009
    149
    Thanks Received:
    7
    Aberdeen
    Country:
    Thanks Hugh,
    I wondered if it was boiling but the indicator on the end of the immersion is in the mid (65 deg) position. Tank & immersion were replaced shortly before we bought the flat 3-4 years ago and since other people in the block have noisy immersion don't think it's a fault.
    Any idea of costs for fitting an unvented cylinder & annual inspection would be much appreciated.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
