Hi
Trying to understand heating systems, but am at the real basics stage
(at college but the course does not do heating I believe)
Combi boilers heat water on demand so when the hot tap is turned on the boiler fires up straight way, no need for controls?
Do some combi boilers have there own timer so this will switch room heating on at set times
If so would you get a boiler with no external controls at all
So that would be the simplest set up (but not a good idea)
I would like to know how you would attach controls to the boiler
If you have a combi boiler with no thermostat how is one wired to it..
Does the boiler perm live go to the stat which then send power back to the boiler to switch it on (or off)
I do find it hard to visualise the wiring diagrams at the moment. They seem too stripped down to the basic info. I cant relate that to actual conductor going into terminals.
