Hi chaps, sorry to spring a first post problem on you.
I had a Heatline VIZO 24HE retro fitted to replace my old back boiler last October. To be honest it has been brilliant (apart from long DHW pipe run) until recently when it has developed a DHW problem.
Problem started with DHW running cold every few minutes and now there is none at all. The CH is fine and works very well.
I have watched the burner and when you open a hot tap the burner comes on and then goes out after about 20 seconds. I have also noticed the red light next to the power light comes on when the burner dies, then goes out again when the burner comes back on approx 45 seconds later.
The Heatline engineer says the heat exchanger is full off crap (classic symptons) without even looking at it.
The rads have been flushed through with Sentinal cleaner and inhibitor added.
So can anyone offer up any thoughts as to what my problem is.
The Heatline engineer is coming out tomorrow but I don't want to be fobbed off with it's not covered matey line.
Cheers
Del
Cheers
Del
