I am re-furbishing my first floor bathroom. I am removing the existing radiator which is just above the skirting board and fitting a new chrome radiator on a different wall. I want to mount this radiator 800mm approximately above the floor ie. the valves at the bottom of the rad will be 800mm above the floor. The rad is 1150mm high.
Will I have any problems with water flow through the rad? Should this work OK?
I have an older (1993) conventional Gravity fed sytem with a Potterton boiler and pump.
Thanks.
Thanks.
