Height of C/U
17 Jan 2010
Dorset
Got to replace a old C/u but at the moment it sits in the down stairs loo and at the top of the wall, about 7'9"
I have no problem it being in the loo but was unsure if a new unit had to be fixed below a set height, to do with Building regs part M.
Have also looked in the BRB but found nothing to say it can't go back in the same place and also all wires come in the top, but as its so high is that OK as well??
Cheers
Lyngarth
Get an qualified electrician in who is registered with the competent persons scheme, this is too involved for a DIYer.
I am a sparky, 7 yrs with Nic but was just checking about the height as on site yesterday myself and two other sparks all come up with different answers to this.
My answer was it would be fine to keep it there and cables through the top would not mess up the ip rating, but the two others said it had to be below 1200 high to keep within the part M regs.
So thanks for your reply, and will wauit to see if any others can help.
Lyngarth
Part M or not, there is a box in the new Schedule of Inspections
It says
"Adequacy of Access to Switchgear and other equipment"
Would you feel able to tick that box with the Consumer's Unit nearly 8 ft up the wall??
Think about accessing it, in the dark. after the B6 had popped.....
They're wrong.
Also, Part M is an Approved Document, not regulations.
By complying with the various Approved Documents, you'll comply with the Building Regulations.
It says
It doesn't stop many so called 'Electricians' on new builds.
Also, anything that requires a step ladder would fall short with that way of thinking.
I stand corrected, on a technicallity.
He mentioned a set height. Set heights are only noted in the Approved Document, not the Building Regulations.
Also, as I said, there's no set height for a consumer unit, only common sense.
I guess I put 2 and 2 together and came up with 5!
His foot was. As a 16yr old I found it soooo funny! :lol: :lol: :lol:
He actually broke a set of cheap aluminum step ladders too. They collapsed underneath him whilst on the second step.
