- Joined
- 1 Apr 2022
- Messages
- 25
- Reaction score
- 0
- Country
Hi all,
I’d appreciate some advice on an unfinished ensuite tiling job, particularly whether the bedding needs correcting before the work continues.
The room is approximately 2.8 × 1.2 m, mostly new studwork with tile backer board. The tiles are Porcelain, 600 × 600 × 10 mm, with smaller tiles on the main shower wall. There is a waterproof layer behind the shower tiling.
The job is around 90% complete, with the adhesive cured but grouting and resin finishing of the mitres still outstanding. Labour is £2,000, not yet paid, and I supplied approximately £3,000 of tiles.
Currently:
- There Substantial visible voids behind exposed edges of the large tiles.
- A zip tie can slide approximately 30–50 mm behind the edges at almost every edge points, and although they haven't admitted it, it seems to be dot and dabbed.
- Measuring through open joints from the tile face and subtracting the 10 mm tile thickness gives approximately 7–15 mm between the tile backs and the tile backer board at sampled locations.
- The finished tiled faces are flat when checked with a 2 m level. Levelling clips/wedges were used.
- The extra build-up has left the tile faces proud of the timber door jamb, contrary to the agreed finish.
We originally discussed a 6 mm notched trowel and approximately 3 mm finished adhesive thickness. I understand a larger notch may have been needed for tiles this size; my main concern now is the actual coverage and support, rather than insisting on a particular trowel.
When I asked the tiler he says the walls were uneven/out of plumb, so additional adhesive was applied locally to achieve a straight finished surface. He says full bedding is only achievable on flat, level walls, but is confident the tiles are securely bonded. He also says some tiles were lifted and re-pressed during installation to check coverage but won't share what that coverage is.
I believe the boards were flat within approximately 3 mm under a 2 m straightedge, although I recognise that flatness and plumb are different, these are all freshly made partitition walls with tile backer board applied and jointed.
The adhesive used is was ARDEX X7 W. The tile's guidance calls for full bedding, and the X7 W instructions say tiles of 0.1m2 or greater should be solidly bedded. No tile has been removed yet, so I cannot confirm whether these are isolated blobs, a combed bed with additional adhesive, or something else.
A video to go along with the photos: https://photos.app.goo.gl/z6eY1CpQhUyQTUiS9
I have a couple of questions on next steps:
Currently:
- Do the attached photos/video suggest significant inadequate bedding, or could this be limited to the exposed edges?
- Would wall irregularities justify these voids, rather than correcting the substrate or using a suitable thicker, continuous bed?
- What would you inspect before deciding between leaving it, local repairs or replacing sections? Is tile removal necessary?
- If similar bedding is found inside the shower, does that change your recommendation? The smaller shower tiles appear better bedded, but the large format tiles in the shower seem to be the same.
- Is there a reliable, manufacturer-approved method of filling voids behind porcelain tiles on waterproofed backer board, or is removal and re-bedding the realistic remedy?
- If removal is needed, how practical is salvaging the tiles and reinstating the waterproofing?
