HELP - Ariston EuroCombi SX20 MFFICE - no flame/dead?
5 Jan 2009
Hi All
Came home to boiler off, CH pressure is ok, fuse is ok, it will not relight off centre ignitoin/reset button ?
It has no external thermostat and the timer switch is constant ON.
I have d/loaded the manual/fault finding and will have a look tomorrow and FREEZE tonight....
It has gas supply.
Anyone help ? Or know of any common faults/things i can test with meter.
Cheers
If the pump is working and operating the system flow switch ( when fitted ) then thats really the limit that a DIYer can safely do.
Its obviously not safe to encourage a DIYer to attempt work that should be carried out by a gas registered engineer in respect of gas/combustion issues.
Tony
PS Whats the point of posting the same question on different forums? You will only get the same replies from the same people!
