can someone point out on the vokera spec sheets where it tells you about the boiler differential ?
Read
http://www.vokera.co.uk/download.asp?id={457825E8-27E2-431F-B5A8-2A41EEEC1F61}&type=literature
You will see that it says "Max heat output @ 80°C/60°C. That's a 20°C differential.
Note This is for the Compact HE, but the Compact HE is the same.
Balancing radiators does not necessarily save fuel. All it does is ensure that every radiator is giving out the heat specified by the manufacturer.
So all modern boilers work off the 20C diff ?
There are still some boilers which are designed for an 11°C differential.
noticed the house felt a bit colder y/day reducing the drops to 20C
Unfortunately radiator output varies with temperature. Manufacturers quote the output according to British Standard BS EN 442, which specifies a flow temp of 75°C, return of 65°C and room temperature of 20°C. If the flow and room temperatures are not changed but the return temperature is dropped to 55°C, the output will drop by about 15%.
Very crudely, the output of a radiator depends on the difference between the average surface temperature and that of the surrounding air. Lowering the return temperature will lower the average surface temperature and consequently the output. If you want to learn more look at
http://www.engineeringtoolbox.com/heat-emission-radiators-d_272.html
In most cases this will not be noticeable as most radiators are oversized; you seem to be one of the exceptions! It would certainly be worthwhile raising the flow temperature, even if the return does get above 55°C. You may not be able to keep the boiler in condensing mode all the time.
If your house is warmer, but you are not using any more fuel, you have at least achieved something. The only way to really save fuel is to have a lower temperature in the house - and wear a jumper!
