Hi guys,
Had a large raft and ring beam poured last week, unfortunately the form work started collapsing and the trenches became really dangerous due to the weather. I was planning to float and polish the raft to use as finished floor, but did not get anywhere near it and had to call the guys off after vibrating.
The proposed timber framed building is meant to be built along the middle of the edge/ring beam, but due to the form work problems I have areas that are lower than the level for the sole plate and areas that are higher (all over the place).
Firstly, I am hoping someone may be able to advise on how I can reduce the levels that are too high, I have a stihl saw and can obviously do loads of chases and knock out the slices, but is their anything more sensible on the market to achieve a flatter leveller finish?
As I am on the edge of the raft, a floor planer may be too wieldy to control.
Secondly, is there anyway I can bring the lower levels up to the ffl? I will use fischer fixings -to fix the timber- that will go through any new material into the existing pour, but am worried that I will not achieve the structural requirements as per the engineers design.
I will be speaking to the BCO shortly and am hoping to be armed with potential solutions before he tells me to break loads of it out!
Any advice greatly appreciated.
James.
James.
