help choosing a dimmer switch
2 Nov 2007
Gloucestershire
I have juts been to buy a dimmer switch to replace the normal light switch in our littlens nursery.
I have come back empty handed. The options were 1 way of two way - i think i need one way as its not part of a two switch circuit.
The other option was for use with or with out an induction circuit - i don't know what this is.
None of them said they should be used with low energy light bulbs.
which one do i need to buy please? with induction or without?
Cheers
Rich
hiya, its worth buying a good quailty dimmer switch. the ones you see typically dont tend to last too long and some "hummmm" badly. i guess you have one light fitting in that room. dimmers do have wattage ratings typically a 250 watt which should be suitable for your application. a plain white 250 watt dimmer made by Hamilton is a good solution for around 8- 10 pounds. thye do do brass etc but are slightly more expensive naturally. that price may be double wat u have seen perhaps but will last more than double the life of the cheapys !! and wont "hummmm" .
Even the best quality dimmer switch will still not dim low energy lamps
very true !! quote
"You can not use any type of dimmers with low energy lamps."
sorry thought that point had been made clear earlier lol i guess we r dealing with some amateur electricians on here only just joined so will try and make my posts idiot proof lol .........
You need to use an inductive dimmer to dim certain types of (extra) low voltage lighting.
Most electronic transformers will dim fine with a standard dimmer, whereas you normally need an inductive dimmer if the transformer is a wire wound torroidal type.
Get a standard dimmer and put back a normal 40 watt or 60 watt light bulb.
Note the dimmer has a minimum lamp rating, usually 40 watt, to work properly.
save the low energy bulb for another room
