- Joined
- 13 Feb 2024
- Messages
- 11
- Reaction score
- 0
- Country
Moved from "Your Projects"
Hello,
We've recieved a survey and its recommended a drainage survey with CCTV due to cracks on the front elevation and in the kitchen. Copy below, is this fairly standard or should we worried?
There is cracking to the front elevation that is likely to be caused
by faulty drainage. A specialist drainage contractor’s report will therefore be required, which
should involve a pressure test, possibly followed by a CCTV inspection. If a defect is found, it is
likely that the drains will be able to be sleeved. However, if defects are found, some excavations
may be necessary as the subsoil/substrata beneath the foundations may have eroded away,
creating voids. Therefore, trial inspection pits will need to be dug to ensure that the matrix of the
earth is stable. If the soil is found to be unstable, further work to underpin the property may be
required. The drainage inspection and trial pits will need to be supervised by a Structural Engineer
who will then be able to provide you with a structural adequacy certificate, which will be required
for your buildings insurance. Once the drains are repaired, and/or the foundations are confirmed
as stable, the cracks can be repointed. All cracks should be raked out to a depth of around 2cm to
ensure a good key for the new mortar. Lime mortar and not cement should be used to allow the
brickwork to breathe. If no drain leakage is found, a Structural Engineer's Specification should be
obtained for any repair work necessary
