Changing an extractor fan today. Thought it was a simple job but now I may need to get a spark in but thought someone coul advise if this would be the best course of action or whetther a simple solution.
Changed fan identifying permanent live which was not needed and fan worked fine. Had a power cut(always getting them here ) so went and had tea and when it came back on went back to carry on tio change the light fitting whic is wired to the fan via a ceiling rose. disconnected old light fitting (downhanger no earth) and used the pull cord to turn on again and the fan stopped working. Took fan off/tested and it is fine. reconnected but still not working. Tested wires to the fan with a screwdriver type tester and the live is ok but the neutral also shows a current. Should this be so ? Why is the fan not working? Could I have distured some wiring in the ceiling rose?
Think I am probably out of my depth now and will probably need a pro
Any suggestion
THANKS
think I am probaly out of my
Any suggestion
THANKS
