Hi All.
I have read up on this issue but the the behaviour of the light is still confusing.
The specs are as follows.
Tube - Sylvania Luxline Plus White Deluxe F58W/835 T8 (pins are about 11-13 mm apart)
Various starters tried:-
Vask Components VKS10 13w, 25-65w, 4-8w, 15W, 18-20W, 28W, 38W 2D, 80W, 220V-240V
Red/Grey F58, single, 220-240v, 80-125W
Starter FS-U, single, 220-240v, 4-65W
I am not 100% sure because I cannot remember well, but I think this is how it went:-
Light worked fine with the Vask starter. One day, only the ends of the tube lit and it blinked at intervals. Starter was replaced with the Red/Grey starter and the very first time the light was switched on after replacing the starter, it came on fine, however, the next time it was switched on, the problem occurred again. The tube was replaced but the exact same thing happened. It worked first time but not on consequent occasions. The FS-U starter was used and the light was left on for several hours when first switched on. After this, it worked fine for several weeks and now it has reverted to the same problem.
So, we have tried changing the starters and the tube and some combinations worked for some time but where does the problem lie? Light case/fitting or wiring (or inappropriate starter)? Yes, I have read that lights with starters are about 15-20 years old, however, our light was bought new from a shop only a few years ago. It is not that we've been using the same light for 20 years!
Any suggestions would be appreciated.
Thanks.
Thanks.
