Help finding a toilet
13 Jan 2016
any idea where I can get a close coupled toilet (ideally as back to the wall as possible) but no more than 750mm in height? I've been searching for ages no luck...
13 Jan 2016
Ive got the Melbourne but hate how much of the soil pipe I can see (it's a vertical soil pipe from the floor with a bend on)
Needs to be standard cistern (not hidden in wall)
Please help!!
13 Jan 2016
Change of plan... I now need a 'back to wall/fully shrouded close coupled toilet'
That ideally projects no more than 620mm
And looks traditional if possible!
H
Hot&Cold
Doubt availability of traditional to match your dimensions,also your existing soil pipe location has to be considered.
There are 1000's of wc combinations available,have you done an internet search including all the words- short projection,fully shrouded,reduced cistern height.
Short projection and fully shrouded are available but height less than 750mm,doubtful as the cistern will be taller but narrow to accommodate sufficient flush water.
There are small wc combinations available for cloak rooms and micro space saver items but why compromise,you need a decent crapper :idea:
28 Jun 2005
Can you post a pic. of the pipe connector - there are some horrors about + some neat ones;)
