Weather struck and cut is different to weather struck pointing. Weather struck is just done with the pointing trowel, whereas struck and cut sticks out out the bottom from the wall and is cut off with a frenchman along the straight edge.You would only need to rake out and retrospectively point if you intended having a different colour to the bedding mortar, otherwise just strike and cut. No need to actively rake out at all.
Load of bolaks.
I can not believe what i have read in the above posts.
P.S this is 2013 not 1920.
They were still doing it that way in the 90's. You remember the 1/4 bond and snap headers mate ?I worked in Germany in 70's and can remember that, although we did also joint up ourselves on some jobs.
There is no justifiable reason that the o.p's wall pointing needs raking out and pointing at a later date. It can be weather stuck and cut without raking also.
You guys are trying to justify his actions by reading off some ancient historic building manual.
The guy is doing it wrong and sounds like he has either been beamed into our century from another time or needs a boot up the backside.
Remember that bond well. The headers were just put in at random and it took a while to work out how it worked. I think you could have no more than 5 headers next to each other, and no more than 5 perps going down in line.They were still doing it that way in the 90's. You remember the 1/4 bond and snap headers mate ?I worked in Germany in 70's and can remember that, although we did also joint up ourselves on some jobs.
The discussion has gone to the methods used to for struck and cut pointing.It's a garden wall, not a Grade I listed building.
That's lovely info' Stu and irrelevant.I doubt if many people have done new work and used weather cut and struck, as it's not used much these days apart from matching in on extensions. Anyone who's done it knows how time consuming it can be, so that's one of the reasons why it was left to the end of the job, as well as getting a consistent colour.
I wouldn't worry too much about her noseall, she got fed of of this hours ago and cleared of to Ultimate Handyman.Whilst i agree to your points regards a certain way of achieving a proud weatherproof pointed finish I can't help thinking that it is distracting and irrelevant to the o.p..
Yes it is. Grade one listed manor house with very fancy white tuck pointing. Well, it could be.It's a garden wall, not a Grade I listed building.
