No
Funny you should say that - a customer of mine with 2 Atmos boilers and a brace of Honeywell stats has just moved into a place with a new Wooshitter and a Wave controller. I have been asked to go in and remove the Wave because it "doesn't do what its supposed to do".
Chap is in for a shock when he see's the work that's going to be needed to maintain his new POS over the Atmos' we fitted in his old place some 11 years ago.![]()
First of all unsightly flue means it complies with minimum clearance dimensions from any openings, so had to be routed away from that door, and it is in a utility room where no one would give a honk, may be you are picking on its slope, it looks level but the inner flue is eccentrically laid to form a slop towards the boiler. So far so good its been going for two years with no problems, no dripping from the flue. The guy was going to put the boiler up on that wall where the flue is existing, but there was going to be problem for condensate drain, and he was suggesting using a condensate pump over the door, and since majority of other plumbing ran on the adjacent wall, therefore he decieded to take this route. The door has since been blocked with a 3/4" thick plywood and stuffed with insulation leaving just the vent exposed. Washing machine sits in front of that door now.Is the flue in Mike from London's £3500 installation correct apart from being unsightly?
MFL, I'm only a humble DIY'er and I wasn't saying that your flue was wrong, just that it didn't look that good and inviting comment.
I agree. The flow and return pipes near the ceiling should have bent offsets, not elbows. He has intertwined the cable amongst the hot pipes as well.Nor the unnecessary junction box on the wall tiles. That's terrible. It all is.
A good ploy. But use some common sense. They may sell say WB parts a lot because many may be fitted in the area. Many housing estates with hundred of boilers may all be the same maker.when I go to get parts I ask whose parts are you selling most of ?? It helps to identify whose boilers break down the most. Worcester are usually at the top of the list.
Dave, I have absolutely no problem with your comments, it is good you made me aware as well, and I did not even raise an eyebrow over that flue slope, photo may be deceiving, but next time I am around Harlow, I will take my spirt level and check, if the installers did not provide enough slope, then they better redo it, I just hope they will acknowledge their error and put it right at no expense to me. I will speak to the company who did that installation, they are based in Harlow, You made constructive remarks, there is absolutely no need for anyone else to use inflamed language and leave nasty comments. Some people are so arrogant.MFL, I'm only a humble DIY'er and I wasn't saying that your flue was wrong, just that it didn't look that good and inviting comment.
A few drops? I'd hardly call the content of the heating system at 120c and 3 bar a few drops. That's like running your electric install without an earth and saying well it's only a few volts for filters in switch mode power supplies.
