Hi
I would like to add a flurecent tube above the kitchen cabinets. To do this I will be changing the single switch currently in the kitchen to a double to use for switch.
I have run the cable from above under the floorboards into the switch. I have also run another cable from the same point (upstairs) to where the tube will be installed. I know I need a junction box at that point. And I know it needs to be wired as per the instructions in:
http://www.diydoctor.org.uk/projects/projectselectrical.htm
My problem is in identifying the FEED cable. I can see that there is another cable that is coming out of the existing light in the kitchen and goes to a 3-gang dimmer which has 4 cables running into it. I am assuming the fourth cable IS the FEED, as I can see the three cables from the dimmer going to the downlighters. I can see 4 cables going into the 3gang dimmer. So the cable I have identified MUST be the FEED.
Im I correct?
Please help.. I'm doing this today!!!!
Thanks all
Im I correct?
Thanks all
