Hello. I don't know much about central heating but ours has stopped working tonight.
It is an old fashioned system with a cylinder. There is a room stat, a stat on the boiler, and a cylinder stat.
I've turned all to the max to check it is not simply this. The pump runs for when I turn the stat up on the cylinder but it seems to only be pumping cold water as the pipes are cold each side.
I'll post a pic of the boiler soon, there is no indication whether the pilot light is running, but I've pressed the ignition button, which didnt have the satisfying click I was hoping for.
What should I do?
Many thanks.
Rob
What should I do?
Many thanks.
Rob
