Help me rescue this adjustable desk project
I'd look at linear actuators. One on each side, floor mounted, powered by the same power supply, would move that up and down nicely.
Would they not get out of sync?
A garage roller door motor might be worth considering. They are tubular, with adjustable limits and drive at both ends.
In theory, no. In my experience, the same make and model are very consistent in their output.
Right, linear actuators are looking like the way to go. Similar "format" to a hydraulic ram but no oil to leak out of them. Lots of different sizes available. Can pair them easily enough. I understand electronics more than hydraulics.
Just need to work out how many Newtons I need. I assume they're just a big threaded screw inside as the load and speed are proportional on all of them.
As often used on steerable satellite dishes. They can provide positional feedback.
10 Newtons = 1 KG
Have you considered a long threaded bar, running on a bearing at the top, nut fixed to the work surface and a reverse-able motor to turn the rod?
I looked at lead screws and the associated bearings, blocks, etc but wasn't sure how to size them. However, it seems like a "linear actuator" is essentially all of that in a package.
From an Aliexpress listing:
Some old architects drawing boards had a foot rest that you lifted with your foot and the whole desk top lifted/adjusted as necessary and will go horizontal too I recall, really quite clever, certainly faster to adjust than any other system available. Sometimes they turn up for not much or even free on Marketplace or ebay.
Bieffe drawing boards was one make, eg
or
Just buy an industry standard workbench (mine are 935mm high) and a draughtsman swivel chair.
2x 450mm 1500Nm linear actuators have done the job. They don't track each other perfectly and they're a bit loud, but they work.
Should have expanded on that a bit...on the test bench they move at slightly different speeds and one is 15mm longer than the other at full extent. But the "carriage" I built that slides up and down is quite rigid in that axis, so it doesn't make any noticeable difference.
