- Joined
- 29 Dec 2006
- Messages
- 4
- Reaction score
- 0
- Country
The gc numbers was on the empty box he left!
He did not give a reciept as he apparently did not have none left or none on him!
Re agile thats a good idea to spread the word but i think this one works for a bigger firm!
I did a search on ebay for that part number and the cheapest i saw was £32 Brand new!
I read on the a1-gas forums that the Heat inside these units makes a 5 way terminal block crumble and drop parts into the fan rotor. causing Fan rotor to stall and stops the airflow thus causing Pressure switch to go off hence so boiler shuts down! SOLUTION: Clear terminal debris and fit a new terminal block. Lubricate motor bearings which were dry. Replaced pressure switch microswitch, which had unreliable connection across one of the contact pairs (Would this be true)
