Hello
Today i changed over another radiator in my home.. straight swap nothing too difficult have done it many times before.
I switched off the boiler and drained the whole system and turned off the water supply (as i normally would).
Swapped over the radiator, turned back on water / boiler etc.
Normally at this point i simply bleed the radiator and the pump screw and everything works perfect and the house heats up quickly.
however when i switch on the boiler i hear a buzz coming from it but no fan, no ignition. ive been trying this on and off throughout the day but it just wont ignite (nor does the fan start)
I haven't actually used my central heating since december so unsure whether my work today has caused this or if has been like this prior.
The boiler is ideal classic se15ff. I have a big tank on the top floor and also a tank in my loft...
ive gone round and bled every radiator again and bled the pump
any suggestions before i call out an engineer!
