hello i need help please.
my front room rad has never been great for warming up,the bottom was always cold and the top luke warm.
i took some advice that there may be sediment at the bottom of the rad.
so i have had the rad removed and there was a lot of black sludge crap, the rad was flushed fully to clear it.
once the rad was re fitted if anything it seems worse??
the flow pipe into the rad is hot but the return not hot so i thought the return pipe might be blocked. so i have disconnected the return pipe and the water feed coming from it is a good jet.
so im completly baffled why the rad dont heat up and seems worse since the flush????
any ideas please i dont want another cold winter with this rad.
my system is run on a combi boiler, with 8 rads.
thanks in advance.
thanks in advance.
