help please with led lit bathroom mirror model 01EL-KAS
12 Dec 2015
Can anybody help please - I have a led lit bathroom mirror (01EL-KAS) which has been working fine for around a year and last week it popped and tripped the fuse board. It's now not working but I can't work out where to start. I've taken the mirror off the front and the bulbs all look fine. There is an led driver and another little box which I presume controls the sensor switch. I'm thinking that maybe I should replace the led driver???
Remobve the mains input to the mirror, check if you get 230v on the supply cable. this will check that the problem is not elsewhere! (I assume you have multimeteror two probe voltage tester?).
Then you'll need to reconnect and see if there is an output from the driver. If no output you need a new driver.
Go back to the supplier. Most mirrors like this have a 3-year warranty
